Splitting or trimming 3D objects
           Tool  |
           Tool set  |
           Project
           3D Modeling  |
The Project tool projects a 2D object or NURBS curve onto a NURBS surface, solid, or subdivision object, and then splits or trims the solid object according to the region selected. This allows nonlinear splitting or trimming of objects to create different shapes or cut a hole in an object.
             Mode  |
             Description  |
             Split
             Splits a solid object with a projection  |
             Trim
             Trims a solid object with a projection  |
             Add
             Adds a projection to a NURBS surface  |
             Add Upward (Add mode only)
             In Add mode, adds the projection in the profile plane normal direction  |
             Add Downward (Add mode only)
             In Add mode, adds the projection in the opposite direction from the profile plane normal direction  |
             Add Both Directions (Add mode only)
             In Add mode, adds the projection in both the profile plane normal direction and the opposite direction  |
